Torq_Shep Posted November 26, 2020 Share Posted November 26, 2020 So I bought the Team Cherokee REAR XJ hinge for the lower hinge on my drivers side door. I will take pictures of everything once I get it out in the sun and put a coat of primer over it. There is a small difference in the front and rear hinges on an XJ but apparently they work just fine on the front. The body side mount is tapered instead of square so there is slightly less weld contact. https://teamcherokee.com/rear-door-hinge-assembly-oem-cherokee-1984-1996/ This is definitely the cheapest way to replace your door hinges if you have already broken one off. Mine had massive wear on the inside half of the hinge. I could have redrilled them to a bigger pin but as one was already busted off I went this route for the bottom hinge. Top hinge is from another member on here but I could have used the rear XJ hinge for both hinges. Link to comment Share on other sites More sharing options...
mnkyboy Posted November 27, 2020 Share Posted November 27, 2020 I used rear door hinges on mine too, they worked great. Rear hinges are especially good when looking for used hinges since rear door hinges typically don't get worn out like the fronts do. Link to comment Share on other sites More sharing options...
