Oizarod115 Posted November 2, 2007 Author Share Posted November 2, 2007 yea its all hooked up right.. and my 5v is red/white stopped by and got a pack of assorted ones including a 250ohm and two 200ohms... i'll burn the 250 in tonight... i figure if 25 ohm can move it .1 then 250 will move it 1.0ish right? idk, we'll see. Link to comment Share on other sites More sharing options...
Oizarod115 Posted November 2, 2007 Author Share Posted November 2, 2007 well i soldered in the 250 ohm potentiometer and perfectly as i suspected i can now vary the voltage from 5-4 which is perfect. :cheers: :cheers: i set her to 4.7~ (thats a very unprecise measurement considering I'm using a few year old analog multimeter on a scale of 1-10 through 90* of motion. now how should i go about seeing if that is a good setting or not, its still got good power, i smelled the exhaust, seems a little cleaner, maybe not 100% burnt though. but its never gonna be perfect right? ..thanks for all the help on this one hornbrod Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 2, 2007 Share Posted November 2, 2007 Since you don't have a wide or narrow band A/F meter to monitor Stoich, pull a spark plug every 50 miles or so and look at the color. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 6, 2007 Share Posted November 6, 2007 How did this work out for you? A couple of guys on the stroker forum are having a rich condition too. Link to comment Share on other sites More sharing options...
FxRacing282 Posted November 6, 2007 Share Posted November 6, 2007 i set her to 4.7~ (thats a very unprecise measurement considering I'm using a few year old analog multimeter on a scale of 1-10 through 90* of motion. ~? i think you mean DC Link to comment Share on other sites More sharing options...
Oizarod115 Posted November 7, 2007 Author Share Posted November 7, 2007 i set her to 4.7~ (thats a very unprecise measurement considering I'm using a few year old analog multimeter on a scale of 1-10 through 90* of motion. ~? i think you mean DC i mean ~ about. wasn't thinkin elec. symbols, but yea DC in other news on this thread, i pulled a plug w/e its set at is just about perfect, but someone brought to my attn that my k&n is dirty to the point it might be hindering my airflow which might be contributing to the rich-ness in the first place :roll: Link to comment Share on other sites More sharing options...
FxRacing282 Posted November 7, 2007 Share Posted November 7, 2007 no your O2 sensor adjusts for the lack of air. and your MAS or MAP should adjust for it Link to comment Share on other sites More sharing options...
Oizarod115 Posted November 29, 2007 Author Share Posted November 29, 2007 alright guys! success, wanted to update the thread for future searches on the topic.. my numbers on the origional test were as follows 223/189 HC 259/194 FAIL-FAIL 6.56/2.36 CO 6.48/1.74 FAIL-FAIL 129/1233 NOx 177/1340 PASS-PASS after building an adjustable map sensor my numbers dropped to (guestimated from what i remember, can't find the sheet from this run, i know i failed the one section only though) these are my 4.8V trial results 150/189 HC 160/194 PASS-PASS 2.1/2.36 CO 2.4/1.74 PASS-FAIL 500/1233 NOx 600/1340 PASS-PASS i acheived that much by adjusting my MAP sensor (go-jeep has a writeup on building an ADJ one) to 4.8ish volts (5v normally) these are my 4.1ishV trial results 82/189 HC 89/194 PASS-PASS 1.01/2.36 CO 1.03/1.74 PASS-PASS 703/1233 NOx 1168/1340 PASS-PASS :popcorn: :deal: :clapping: these test results were all on premium gas fully warmed up ~210-215* motor NO OTHER MODIFICATIONS were made between tests, just MAP sensor, and you can see how much it affected the results. note: pay attention to NOx emissions as reducing voltage will cause a leaner fuel-air ratio which lowers HC/CO but increases NOx, this will only help you to pass emissions if your truck has LOWLOWLOW NOx emissions like mine did, and HIIIIGH CO/HC (an indicator of rich fuel-air mix) reducing the voltage at the MAP sensor can also increase gas mileage, but be careful to not reduce it to much and F the motor up. happy searching! Link to comment Share on other sites More sharing options...
