As the title says I can’t separate the fuse box connector from the engine side. I’ve loosened the 1/4” bolt but it won’t come out.
Ive tried to pull them apart with the bolt loosened, but have had no luck. Any idea what’s going on?
Could be just stuck, are you pulling straight back? Are you sure that the screw is out all the way, iirc it's a long screw
