Renix Factory Vacuum Configuration
I had a HO 4.0 rebuilt for my 88 Pioneer that was in a factory configuration. Added Borla head/exhaust and ran the HO Intake manifold and TB. Recently got a job in California and have to convert everything back for CARB compliance. Luckily I have all the original parts except the airbox.
There are a couple tings that I need clarification on when I swap the intake, TB, and vacuum lines. Can someone post up some picture of a factory vacuum line setup, particularly what is where on the intake manifold. (See color coded pic)
I think I'm missing some fittings on the TB for the MAP vacuum line. (See pic)
Also do I need order a filter or diffuser for this vacuum port in the airbox (see pic)
23 minutes ago, cruiser54 said:
Green brake booster
Blue IAT sensor
Purple Vacuum for the vacuum reservoir/dash vents/cruise control.
Perfect, thank you! Do you have the diagram for the reservoir, hvac, cruise, 4wd? Just want to make sure i get it all back to factory.
Much appreciated
