Cabz Posted March 18, 2006 Share Posted March 18, 2006 After in stalling my MJ d44 I have noticed that is seems to be kinda noisey, I jacked it up and spun one of the rear tires by hand and noticed that I could here the spider gears just a clickin away. It is the same on both wheels ?. I had the diff opened up and everything looked fine. it had no eccessive play, no chips or bad wear, But still when I turn the rear wheels ( by hand ) and also when I am slowing down while drivin it . You will hear this clickin - :? anyone one have any idea what could cause this? By the way this is a Trac locl LS D44 Link to comment Share on other sites More sharing options...
pingpong Posted March 18, 2006 Share Posted March 18, 2006 Sounds like it might be bad bearings :shock: :( I don't know if you removed the shafts and mixed them up, but they are slightly different in length. Patrick Link to comment Share on other sites More sharing options...
Cabz Posted March 18, 2006 Author Share Posted March 18, 2006 The bearings look fine I chnaged out one shaft from anothe D44 and from the same side. The Dana web site says both shafts are the same length, Same part number for both. Link to comment Share on other sites More sharing options...
holeski Posted March 19, 2006 Share Posted March 19, 2006 Some of the older 44 LS just make noise. I one I have for the J-10 does the same thing. Did you check the R&P backlash? Throw some die on the teeth and make sure you have a good pattern. Link to comment Share on other sites More sharing options...
Cabz Posted March 19, 2006 Author Share Posted March 19, 2006 Some of the older 44 LS just make noise. I one I have for the J-10 does the same thing. Did you check the R&P backlash? Throw some die on the teeth and make sure you have a good pattern. The back lash is good just about perfect actualy :D It's those silly spiders makeing the noises :evil: All seems to be well inside , no strange wear patterns and no teeth missing or chipped Link to comment Share on other sites More sharing options...
