Huge Engine Oil Leak ??
You just swapped the distributor right? Was the o-ring on the new one in good condition? Was it a good interference fit when you installed it? If the o-ring got torn, or just isn't the right size for the hole you'll get an oil leak like that.
34 minutes ago, AMC86Kid said:
Could I use this
to seal the threads on the tie down bolt
Don't think the tie down bolt needs sealed. I recently messed with the one in my 2.8 and didn't have any leaks. It's probably coming from around the shaft of the distributor.
Well the oring swap stopped the leak
after I monkeyed around with getting it on and fixing the timing for hours it runs
now I gotta clean up all the oil, and re top it off with new oil
also I’m gonna look up how to hook up an oil pressure gauge
