Fuel Pump Recommendations
the current fuel pump i have is just located outside but right next to the fuel tank
my problem is that alot of times it fails to provide enough pressure to get the fuel all the way to the carb
so my plan is to find a stronger fuel pump to swap this one with
and to put this weaker one half way up so that way i have two fuel pumps
this way the first pump only has to go up the fuel line half way
and the other pump pushes it up the other half thus making it easier for the pumps
so i was wondering if anyone recommends any pumps that are at 8 psi since my fuel pressure regulator next to the carb maxes at 8 psi
https://www.autozone.com/external-engine/fuel-pump/spectra-premium-gasoline-diesel-fuel-pump-e8016s/191528_11979_5320&searchText=E8016SExternalFuelPump1.jpg
