Hey guys, quick question about relay wiring. I was cleaning up the connectors and labeling which relay is which and I notice that my O2 relay has the wrong color cables going to wrong ports. Attached is the photo of the back of my relay socket and also attached is a screenshot of the 1988 wiring diagram. It seems that on my socket I have Yellow and Grey/Yellow on 85 and 86 and the Orange from the Fuel Pump Relay is on 30 when it should be on 86. Anyone notice anything weird like this? Any quick tips on testing?
Also another interesting thing is my A/C Clutch Relay is nowhere to be found. The cable is cut at the A/C Clutch and there are no more cables leading into the relay center. Is that relay usually located in the relay center?
IMG_3152.HEIC
Error is in the schematic. Can't see your photo, but if its as follows, its correct.
30 - ORN
85 - GRY/YEL
86 - YEL
Yes
Awesome! Thanks Ohm! I thought the schematic didn't make sense. I figured the Yellow ignition cable would make the most sense to go to 85 or 86. Now to rebuild the A/C Clutch relay circuit...
