dante2 Posted May 9, 2020 Share Posted May 9, 2020 This is the piece that pushes down on the Park release when you push the floor shift button in. What is it called? Do they still make these and where do I find it? If unavailable any ideas on fabbing one up? Link to comment Share on other sites More sharing options...
JMO413 Posted May 9, 2020 Share Posted May 9, 2020 I believe it was only serviced with the shifter. Best bet would be junk yard shifter. iMHO Link to comment Share on other sites More sharing options...
dante2 Posted May 9, 2020 Author Share Posted May 9, 2020 Been thinking about fabbing up a steel rod with a slight bend to it if nobody has any better suggestions. Probably going to need both of them replaced eventually. Link to comment Share on other sites More sharing options...
