Missobrien93 Posted May 6, 2020 Share Posted May 6, 2020 In need of advice... so doing a 3in lift kit would the control arms need to be replaced? Or could you just replace the bushings? Link to comment Share on other sites More sharing options...
Dzimm Posted May 6, 2020 Share Posted May 6, 2020 3" is as tall as you can go without replacing them. What will happen is your axle will get pulled backwards in the wheel well and rotate. It would be best to get new longer ones, especially if you plan on replacing the bushings. Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted May 6, 2020 Share Posted May 6, 2020 IMO, I would get good quality adjustable ones. That way you can dial in where your wheel sits in the wheel well and your caster angle. Personally I set mine for ~10* an love the road feel of it. Plus, good quality adjustables will let you move to a bigger lift down the road if you want. Link to comment Share on other sites More sharing options...
