Leaking Transfer Case
How clean and smooth is the nose of the driveshaft yoke that fits into that seal? If there's any rust or pitting, the seal won't be able to make a good seal.
Also, if you replace the seal, wipe some oil or ATF around the lip of the seal and on the yoke so you're not sliding a dry part into a dry seal.
