Williamj467 Posted April 19, 2020 Share Posted April 19, 2020 Installed 3" front end leveling kit add 32" tires. Tire rub lower control arm when turn all the way?? Link to comment Share on other sites More sharing options...
Eagle Posted April 19, 2020 Share Posted April 19, 2020 This is a common problem. The solution is to replace the lower control arms with LCAs from a Grand Cherokee WJ (1999-2004). They have a bend in them to provide tire clearance on turns. As a side benefit, they are also stronger. Link to comment Share on other sites More sharing options...
Pete M Posted April 19, 2020 Share Posted April 19, 2020 yup. you'll need to trim the metal bushing to be flush with the rubber bushing, but after that they should go right in. Link to comment Share on other sites More sharing options...
