70barracuda Posted April 15, 2020 Share Posted April 15, 2020 Trying to cleanup the wiring in my engine bay for the LS swap and also trying to find out what stuff does to see if I can use it. This connect is on the pass side. So far the only wire i can trace is a couple from the a/c relay and one wire that I got tach signal off of. Does anyone have a pinout of the connections? Diagrams haven't been great Link to comment Share on other sites More sharing options...
thecodemonk Posted April 16, 2020 Share Posted April 16, 2020 Based on your description, it may be for the A/C pump (when to engage the clutch when you want A/C but also to disconnect the AC clutch at high RPMs to prevent over-running it). Link to comment Share on other sites More sharing options...
