boxyjeep Posted March 10, 2020 Share Posted March 10, 2020 Going to be swapping in 97+ doors on my MJ and running into some issues with the electric door locks. I've wired up the windows and mirrors and those are working as expected. I have the whole harness, switches, locks/mirrors/windows out of the truck on a bench and for some reason can't get the door locks to work consistently. I have 3 wires coming from the passenger switch that I'm not 100% sure where they should be connected. I've used the factory service manual to wire everything up, but have DB/PK, LB/RD, and LB left over. LB should be coming from IGN SWITCH SENSE (so I'm assuming I can just wire this up to ACC power). The DB/PK and LB/RD should be coming from the OVERHEAD MODULE, which I assume is related to keyless entry. Both wires appear to be 12v constantly when I test them. Any advice on this? I followed most of this guide, but they specified jumping the LB/RD and LB wires together, which didn't make much sense to me. Also, the door locks are out of the truck. Not sure if they need to be in the truck/grounded/hitting the striker/etc. Link to comment Share on other sites More sharing options...
boxyjeep Posted March 11, 2020 Author Share Posted March 11, 2020 Dug into this a bit more and believe the issue was bad door lock actuators. I ordered a few more and should know soon. Link to comment Share on other sites More sharing options...
boxyjeep Posted March 12, 2020 Author Share Posted March 12, 2020 Got the door lock actuators, but they weren't actually the issue. Had to "adjust" the wiring and connector for the door locks a bit and now all is well. Was able to even wire up my remote start/keyless entry to the door successfully. Link to comment Share on other sites More sharing options...
Airborne Janitor Posted March 13, 2020 Share Posted March 13, 2020 20 minutes ago, Chargum85 said: Got the door lock actuators, but they weren't actually the issue. Had to "adjust" the wiring and connector for the door locks a bit and now all is well. Was able to even wire up my remote start/keyless entry to the door successfully. What did you tap into to get your remote start/ keyless entry to work? Link to comment Share on other sites More sharing options...
boxyjeep Posted March 13, 2020 Author Share Posted March 13, 2020 14 hours ago, Airborne Janitor said: What did you tap into to get your remote start/ keyless entry to work? The Keyless Entry module had a few wires for lock/unlock. I just tapped those into the lock/unlock signal wires (OR/VT and PK/VT) in the harness. Since it's a ground trigger, no relays were needed. Link to comment Share on other sites More sharing options...
Airborne Janitor Posted March 13, 2020 Share Posted March 13, 2020 7 hours ago, Chargum85 said: The Keyless Entry module had a few wires for lock/unlock. I just tapped those into the lock/unlock signal wires (OR/VT and PK/VT) in the harness. Since it's a ground trigger, no relays were needed. Good to know. Thanks. Link to comment Share on other sites More sharing options...
CatfishJoe Posted April 2, 2020 Share Posted April 2, 2020 Hey Chargum, glad I could help some! I'm honestly not too sure about the LB/RD + LB splice either, but it seemed to be required for mine to work. What was the issue with the door connectors? Janky terminals? Link to comment Share on other sites More sharing options...
boxyjeep Posted April 2, 2020 Author Share Posted April 2, 2020 7 hours ago, CatfishJoe said: Hey Chargum, glad I could help some! I'm honestly not too sure about the LB/RD + LB splice either, but it seemed to be required for mine to work. What was the issue with the door connectors? Janky terminals? I spent some time testing and debugging this and don't remember exactly how or why, but this works well. There are two wires that go to the overhead module that have a constant 12v current, except for when lock/unlock is triggered. Jumping those two gives power to the appropriate wire at the right time. Link to comment Share on other sites More sharing options...
