Fuel pressure specs needed
31 PSI with the vacuum hose connected, 39 PSI with the vac hose disco'd.
I'm pretty sure about those.
Well I left early today and didnt get the info about the vac hose off /on, but i did check pressure. it was a lil over 36 with key switched on. with it running it was like 39/40ish range.
Is that to high?
Is that to high?
the regulator is like 40 bucks IIRC, mine was spewing fuel so it got replaced.
idk how that helps you but there ya go!
Is that to high?
I think you misunderstood me,, I was saying it was 36 PSI and around 40 PSI
But thanks,,,jt
