Wire identification , connector for fuel pump "under chassis harness" (C157?)
I'm trying to combine the chassis harness from an 88 mj to the dash harness of an 89 cherokee.
I have an image of what I believe is the correct connector on the 88 but need to know the wires, can't find them specified in the diagrams.
I believe Orange is pump hot, tan is sender.
I believe this is the XJ side.
UAgPnQF.jpg?1
UCaNd3e.jpg?1
19 hours ago, Ωhm said:
Its no where to be found. Over time I figured it out. That why I said "double check it".
You have a better memory than I.
Any chance you keep the wiring for the gray connector in there?  C118 I think.
Should be speaker stuff and cab wiring I think.
Just now, Ωhm said:
Since you know the connect number, do you have a copy of the 88 Electrical Manual?
I do but it doesn't have the connectors in there. So I have to know what components it goes to.
up to 4 out of 10.
Brn/wh LH speaker - (connects to blk/ yellow)
Grn/wh LH speaker +
Brn RH speaker -
wht/blk RH speaker + (connects to wht)
You mean it doesn't have the connector pinouts with circuit names? Because that's true, but as a example, go to page_56, find C118 for callouts. Page_63 for interior lights. Does this help?
