Phillip Gwin Posted February 15, 2020 Posted February 15, 2020 I am sure someone has already asked, but here it is again. Does anyone have a wiring diagram for 98 Cherokee doors? I have made them fit, changed the strikers and aligned them. Now for the daunting task of wiring them.
AZJeff Posted February 15, 2020 Posted February 15, 2020 I have the ones for a 2000 XJ, which should be the same. Do you want just the diagrams for the wiring, or the pin-outs for the connectors as well?
Airborne Janitor Posted February 15, 2020 Posted February 15, 2020 I just finished this project this week. This is the best write up with wiring diagram I've seen. I was going to take some more photos and update the thread with some info this weekend.
Phillip Gwin Posted February 16, 2020 Author Posted February 16, 2020 The wiring, I cut off the connectors, just need the wiring diagram. The manual I have just shows the plug, not where the wires go.
AZJeff Posted February 16, 2020 Posted February 16, 2020 Here is the diagram from the 2000 XJ shop manual for the four door. I suspect a two door is the same, minus the other wires to the back doors.
