shagtn Posted March 14, 2006 Share Posted March 14, 2006 I was replacing the brakes/rotors and I stripped the caliper pin when trying to disassemble the caliper to remove the pads. I am positive they have been on the truck since it rolled of the line and Rather than mess around with drilling the pin out I called the parts store and they have the calipers I needed so I picked them up (and new caliper pins) and there is only one piece in each box. I am currently at work and going off memory, but are there not 2 pieces to the caliper or am I remembering wrong? Or is the other side called something else and I need to order it seperate? Thanks, -Will Link to comment Share on other sites More sharing options...
Bounty Hunter Posted March 14, 2006 Share Posted March 14, 2006 The caliper is 1-piece, with two pads. Link to comment Share on other sites More sharing options...
mjeff87 Posted March 14, 2006 Share Posted March 14, 2006 The anchor pins thread into the knuckle. If those threads are stripped out, you can repair with a helicoil (or replace the knuckle :( ) Jeff Link to comment Share on other sites More sharing options...
shagtn Posted March 14, 2006 Author Share Posted March 14, 2006 Excellent ..thanks guys. I don't think the threading is stripped, I just rounded off the Hex Head as I was trying to break the pin loose. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted March 15, 2006 Share Posted March 15, 2006 Be sure to use anti seeze on those threads!!! that way NEXT time everything will come apart as it is supposed to!!! CW Link to comment Share on other sites More sharing options...
