Climb over it Posted December 27, 2019 Posted December 27, 2019 I recently overhauled the engine on my 1986 jeep comanche 2.5 tbi....I did a new timing chain kit and water pump and oil pump among other things....before I started all this the injector was fine but I put it back together (not all the way but enough to let it run) and it would turn over but wouldnt fire...I checked everything out and found no fuel coming from injector...does anyone know why the injector wouldn't even be spraying??
eaglescout526 Posted December 27, 2019 Posted December 27, 2019 Have you tested the CPS? Are you getting spark? Does the fuel pump prime and do you hear it?
Climb over it Posted December 27, 2019 Author Posted December 27, 2019 What's a good way to test the cps? And spark? But I know the fuel pump is working
Climb over it Posted December 27, 2019 Author Posted December 27, 2019 It was running and driving before I did this not very well but it was.
eaglescout526 Posted December 27, 2019 Posted December 27, 2019 Theres a test on Cruisers website that shows you how to test it with a multimeter. I believe you test for AC and its at .2 or something like that, it is bad. You can test for spark by pulling a plug out and keep it attached to the wire at the rotor and put the plug against the block and look for a blue spark from the plug while someone cranks over the engine. Also you can pull off the inlet line and see if fuel comes out. Sometimes the hose inside the tank can be loose and pop off or have holes in it causing little to no pressure.
Climb over it Posted December 27, 2019 Author Posted December 27, 2019 Ok thanks! I'll check on that tomorrow and keep you updated!
