Mid 91 & older fender mounted washer bottle in MO
schardein
I have this original 91 washer bottle.  Mid 91 they went to the bottle mounted on the pass firewall.
Bottle is from an XJ and has dual pumps with wiring pigtails.  Missing the fluid level sensor.  $5 + shipping.  Was going to pull the pumps and trash it, thought I'd check here first.  You can ballpark the shipping at 2 pounds from zip 65570.  Sensor opening is about 1.25", someone ingenious could probably come up with a plug of some sort.
EDIT: Out with the trash.  I kept the two pumps and the cap assembly if anyone is looking for those.
Archived
