All around mj Posted October 30, 2019 Share Posted October 30, 2019 Yesterday I locked my doors. When I got back I unlocked them and the passenger side will not open. I think I have an idea of what I need to do, but I figured I would see if anyone had dealt with this issue before and if they have any tips, tricks, or suggestions. Link to comment Share on other sites More sharing options...
mjben Posted October 30, 2019 Share Posted October 30, 2019 Roll the window down, and standing outside use one hand to reach in and rock the lock lever back and forth while trying the outside handle with the other hand. Once it opens, it's time for cleaning/lubrication/inspection. This has worked for me in the past. Hope it helps! Link to comment Share on other sites More sharing options...
All around mj Posted October 30, 2019 Author Share Posted October 30, 2019 7 minutes ago, mjben said: Roll the window down, and standing outside use one hand to reach in and rock the lock lever back and forth while trying the outside handle with the other hand. Once it opens, it's time for cleaning/lubrication/inspection. This has worked for me in the past. Hope it helps! Thank you for the response. I’ll go give it a try and let you know the results. Link to comment Share on other sites More sharing options...
All around mj Posted October 30, 2019 Author Share Posted October 30, 2019 12 minutes ago, mjben said: Roll the window down, and standing outside use one hand to reach in and rock the lock lever back and forth while trying the outside handle with the other hand. Once it opens, it's time for cleaning/lubrication/inspection. This has worked for me in the past. Hope it helps! Okay, that did the trick. It seems as though the lock doesn’t want to disengage all the way until you play around with it. It felt like it was unlocking, but I felt the switch/button move a bit further when it actually did unlock. Looks like I have just added more to my “Spring time tear down and rebuild” list. Thanks for the help. My brother in law and I were both trying to get the door to open for a bit yesterday and eventually gave up. Link to comment Share on other sites More sharing options...
