mancheflo Posted September 28, 2019 Posted September 28, 2019 Just put some old stock xj wheels on my Jeep and was checking the clearance out and as I had fully turned to the left and was checking it out and as I was looking I got sprayed by some fluid then looked into the engine bay and noticed some fluid in there too, could this be my power steering pump gone bad?
JustEmptyEveryPocket Posted September 28, 2019 Posted September 28, 2019 1 hour ago, mancheflo said: some fluid Gonna need some more info here. What color fluid? What did it smell like? Where did it come from? Where was the fluid in your engine bay? Right now all I can saw with authority is that you might have an oil/ coolant/ power steering/ transmission/ differential/ gasoline/ shock/ etc. fluid leak. Probably should get it taken care of though!
mancheflo Posted September 28, 2019 Author Posted September 28, 2019 1 hour ago, JustEmptyEveryPocket said: Gonna need some more info here. What color fluid? What did it smell like? Where did it come from? Where was the fluid in your engine bay? Right now all I can saw with authority is that you might have an oil/ coolant/ power steering/ transmission/ differential/ gasoline/ shock/ etc. fluid leak. Probably should get it taken care of though! I have a small pinhole leak in one of the power steering hoses
JustEmptyEveryPocket Posted September 28, 2019 Posted September 28, 2019 2 hours ago, mancheflo said: I have a small pinhole leak in one of the power steering hoses Problem solved and solution found: replace said hoses. New power steering pump should be fine.
