fuel quick disconnect clip leaking
dj5
the line closest to the firewall going to the fuel rail is leaking
I'm not sure of how to remove and replace as when I look it up there are a lot of different kinds and some need a tool
my xj has a different kind of clip so I'm not sure of the mj
my fuel line closer to the front of the jeep, I replaced that clip awhile ago and was simple but the back one doesn't wanna come off but has about 1/4 inch of play that I can push and pull on the connection to the fuel rail
any suggestions?
15 hours ago, fiatslug87 said:
How did the two o-rings look?
so that's what I'm trying to figure out....
I can't find any O-rings or the spacer?
I know from what ive seen is its supposed to be o-ring, spacer, o-ring but like I said I don't see any of that, just the plastic clip
43 minutes ago, fiatslug87 said:
Are you sure they're not stuck down in the line? Try taking a pick and fishing for them.
if they are...they are way down there, I don't see anything
I bought a new fuel repair kit that matched up to the 83502745 part number
so hopefully that will work good for the $20 it cost at napa.
waiting for delivery to be at store in like 30 minutes
