90 MJ- Fuse Block Confusion...
This is going to sound crazy, but in my efforts to solve some electrical gremlins with my 90 MJ (manual 5spd 4.0L) I think I have realized that the fuse block is mounted 90* off what schematics show.  My Hazard Flasher is upper right, and my wiper/washer circuit breaker is middle/bottom.  Turn signal flasher is lower/left...  Everything seems turned 90* counter-clockwise...
Is this possible??  The underhood connector does not look like it was messed with at all.
Also one more thing...  I need to replace the wiper/washer circuit breaker, does anyone know what part number I need?
Thanks!!
Andy
4 hours ago, Jeep Driver said:
Yours is mounted correctly just as you described as for the breaker part number I will post it when I get home if somebody doesn't do it before
Great, thanks for confirming that.  I couldn't imagine how it would be different, but I am not the first set of hands (or the second, or third...) under this dash.  Yes, if you could dig up that part number that would be great.  Mine is non-existent at the moment.
