Cabz Posted September 15, 2007 Posted September 15, 2007 I will have my new tcase this week and be ready to yank my dead pukegoat out . I have the ax15 all ready and the tcase is a 98 XJ case 231 with the sealed output. the question I have is both of my DS are new , Am I gonna have to replace them or cut them any? This is all going into my LWB 88 MJ . I am hopeing to just be able to use the shafts I have without any mods to them . any ideas on what I should be in store for?
Oizarod115 Posted September 16, 2007 Posted September 16, 2007 the cases should be within 1" overall length. so you probly won't have to change D/s length unless you do a serious lift at the same time
Cabz Posted September 16, 2007 Author Posted September 16, 2007 no aditional lift at this piont . I have a 4.5" lift now when I swapped in the rear D44 I had to have the driveshaft shortened about 1" and I had to have the front shaft redone when I swapped in the 94 XJ d30. I had just heard the ax15 was a hair longer than the pukegoat and it seems like the outputshaft on the XJ case is longer as well, so I figured I would run it by the experts :D . I can hardly wait to get this swap done , I havent been able to drive the MJ for a few weeks now and it's killin me. Driveing my 4cyl 5spd YJ with lockrights front and rear is a bit anoying as a DD
