1991 Comanche 97+ swap in progress. Nebraska
MJMOPARMAN
The Jeep Gladiator has hit the dealership and I want one, putting out a feeler on my Comanche to see if there is any interest in it. While my goal continues to be to finish the Comanche, if the right person comes along that wants to pick up where I'm at I'll let it go to move on to the next project. I'm sure I'm forgetting 100 things I've done to it, please feel free to ask questions. PM me if you would like my phone #
1991 Comanche. 1998 swap in progress. Truck is now in running and driving condition with the full drivetrain and dash installed. The front axle needs to be re-geared to 4.11 and the front driveshaft installed.
While there is still work to be done, the hard parts are all finished. The cab was painted so just the box and front end need to be finished.
I have new carpet and headliner ready to be installed. they radio wiring is in the dash but still needs to be run to where the speakers will be.
Drivetrain:
1998 4.0 L-6 with 25X,XXXmiles
Head gasket done
Melling high volume oil pump
High flow water pump
2000+intake with new heat shield
New exhaust manifold.
New radiator and hoses
New MOPAR oil pressure switch and pigtail
1998 AW4
Removed oil pan and resealed with new fluid.
External Transmission cooler with all new cooler lines installed.
1998 231-J transfer case
Slip yoke eliminator installed
BG transfer case fluid
Tom Woods rear drive shaft.
2000 Explorer 8.8 rea axle
Flipped spring over axle - Iron Rock Off-road
Disc brakes
4.11 gears.
Dana 30 front axle (needs re-geared)
Iron Rock Off-road Critical path 6.5" front suspension
Steering:
JRC Off-road 1 ton UTK
Power steering cooler with all new hoses
ZJ Pitman arm
Fuel:
Dakota fuel tank
New Dakota fuel pump
5 Wheels and Tires:
Tires 33x10.50R15
Dick Cepek Extreme country
Bushwacker Flares
Interior:
1998 Dash
ALL new A/C components
Compressor
Lines
Drier
Evaporator
Condenser
Heater Core
Heater hoses
New carpet
Faux suede covered headliner.
Here is a link to my build thread:
  • 4 weeks later...
Archived
