i have a comanche d44 that i will be putting in my MJ but i don't have the spring plates/shock mounts for the d44.
does any one know where i can get these? or want to make me some :D ?
ruffstuffspecialties.com
he's got 1/4" spring plates for $40 for the pair.
and shock mounts for 14 a pair.
thanks for the site......
BUT... i realized i messed up.....i need the u-bolt plate that goes under the axel and has the shock mount attached :nuts: is that any better?
I think that you are going have to make something work form the bone yard. Or if you can find some one that has the factory D44 and went to spring over they may have the part you want. because the D44 has bigger tubes than the most stock D35.
might look at the exploder spring plates, they had shock mounts on them, but they're angled funny.
what's your timeline? I'll have mine in about two months free.
The studs are beat up, but you could weld new stud in place.
Hopefully i'll have her all put together by the 28th (truck show in vermont)
thanks for the offer :cheers:
