benjy_26 Posted May 16, 2019 Share Posted May 16, 2019 Hello all. I recently installed a full dash cluster in my '87 Sportruck. The cluster I obtained came out of a '88 XJ with a 4.0, so the tach is off (by 33%, I think). Now, I know that the proper way to adjust a tach is to install a reference tach, start the engine, and adjust the on board tach to match the reference. What I was wondering is this: since Jeep only used a 4 and a 6 cyl engine in these vehicles, would turning the adjustment knob all the way over to the opposite end of the adjustment range get me the correct readings, or should I just do it the proper way? Thanks in advance! Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 16, 2019 Share Posted May 16, 2019 I did this with my blue cluster. I turned the pot dial all the way to the left for four cylinder after installing it and fiddling with it to see where the right RPM was. I thought I would’ve needed a reference tach at first but after I got my REM the tach was correct to what the REM was saying. + or - 100 RPM. All the way to the right is for 8 cylinders. Link to comment Share on other sites More sharing options...
benjy_26 Posted May 16, 2019 Author Share Posted May 16, 2019 Cool! Thanks! Link to comment Share on other sites More sharing options...
JYau Posted April 24, 2025 Share Posted April 24, 2025 I saw this thread a few months ago and thought wow perfect, I can adjust my tach to accommodate my 2.5. So I finally got around to it this week. However, I turned the pot dial all the way to the left and at idle the needle wouldn't even go into range, it still sat below scale. So then I turned the pot dial all the way to the right and now it is better. It sounds and looks like it might be riding a little high like +500 rpm. Link to comment Share on other sites More sharing options...
