AX-5 Overhaul
Club,
I'm stuck with how to get my AX-5 Comanche 4x4 5 speed transmission working?
I've spent the last 6 months trying to have it re-built with very little success.
All the rebuild parts I purchased from eBay seem to be correct, but it still won't shift into or out of 1st or second gear?
When the transmission is manipulated on the bench, all seems fine, but when it is re-installed into the truck, it ain't happenin'
What if anything can I do to trouble shoot this issue?
The main input shaft was replaced, along with the gear cluster, in addition to the main bearings and syncro's.
Something seriously goofed up!
HELP . . .
Cheers,
SGTSnacks
Wow. This sounds really familiar to me.
When you remove it from the truck and put it on the bench, do you find the reverse or fifth gear engaged?
This was my problem when reinstalling my trans, the fifth gear would slide in and I could not engage any gear unless I removed it from the truck and put the trans back into neutral. The problem was tilting it back and the trans would slide into gear.
This trans is long gone as it grenaded it self.
