Hello trying to wrap up my parts list to get started on my build, my truck is a 88,
I'm pretty sure this is the extent of the parts i have left to acquire on my list, please don't price gouge me we are all broheims trying to revive relics of the past.
Clutch pedal,
Manual brake pedal,
Manual cross member, was told this works with a aw4 cross member as well, just need adapter plate( correct if wrong )
Manual floor pan
You do not need a different floor pan and you should be able to use your factory crossmember. Both my comanche and my cherokee had a seperate set of holes in the unibody frame that were threaded to accept the studs and shift the crossmember forward or back.
Also the brake pedal is part of the clutch and brake pedal assembly. You will need that whole assembly.
