Gas gauge
FSM troubleshooting for gas gauge:
  • Ignition in RUN position
  • Disconnect C139 ... Needle should go to F(ull). If not ...
  • Connect C139. Place ohmmeter on C203. Resistance should indicate between 0 and 88 ohms. (0 if tank is empty, 88 if tank is full.)
C139 is the connector at the back of the vehicle, where the pigtails from the fuel pump and sender connect.
C203 is where the sensors plug into the cluster. The feed for the fuel gauge is the tan wire.
