Negative camber front axle help
Good evening everyone!
Question is at hand that my camber is off after my trip in ocotillo wells in Cali, my negative camber passenger side is roughly 3 degrees and 2 degrees on driver. I have been doing researching for the last 2 days and I have come up with: axle is bent, axle housing is tweaked, bent "C's," ball joint issues, wheel bearing issues, alignment technician error and so on. So basically nothing so far. Keep in mind that I have HP30 super dana and lift of 7inches with long arms on 35 inch tires. I have put on 1 ton steering system (drag link, tie rod, track bar from Currie), please help if can and thanks. Right now for what I can is I have stock ball joints currently and will change to HD ball joints to see if that helps. I will upload pics soon.
