ruralandalone Posted October 8, 2018 Share Posted October 8, 2018 As I work through the gremlins in and around my instrument panel, I note that the left indicator does not work, (but the turn signals do). Assuming that I need to replace the bulb, am I correct in assuming that the instrument cluster has to be removed to replace the bulb? Anyone know what kind of bulb it is? And for information, the other obvious problems are: gas gauge does not move, low gas light stays on oil pressure stays pointing to the right, well past the gauge numbers. Link to comment Share on other sites More sharing options...
Jeep Driver Posted October 8, 2018 Share Posted October 8, 2018 Yes, you'll have to pull the cluster, type of bulb will become obvious to you. I just threw away about twenty of them otherwise I'd have sent them to you. Link to comment Share on other sites More sharing options...
Dixie Posted October 8, 2018 Share Posted October 8, 2018 It’s a 194 bulb Link to comment Share on other sites More sharing options...
ruralandalone Posted October 9, 2018 Author Share Posted October 9, 2018 Thanks for the info. And I appreciate the thought Link to comment Share on other sites More sharing options...
