NC Tom Posted September 12, 2018 Share Posted September 12, 2018 This is most annoying! Was having slow start issues when cold, fine after initial start. Replaced battery last week. Been running fine for the past 5-6 days. This morning, I get back from taking my son to school and my wife goes to start the MJ and NOTHING happens! No lights, no crank or click! It's as if there is no battery. This occurred, literally, 15 minutes after I parked it after have no issues. What the hell!?!?!? Link to comment Share on other sites More sharing options...
Pete M Posted September 12, 2018 Share Posted September 12, 2018 what's the condition of the cables? My truck was notorious for corrosion creeping in between the cables and battery posts. Link to comment Share on other sites More sharing options...
NC Tom Posted September 12, 2018 Author Share Posted September 12, 2018 2 minutes ago, Pete M said: what's the condition of the cables? My truck was notorious for corrosion creeping in between the cables and battery posts. Recently replaced. Link to comment Share on other sites More sharing options...
Pete M Posted September 12, 2018 Share Posted September 12, 2018 double check and clean all your connections. if you can't even turn on the headlights, that's gotta be a clue. Link to comment Share on other sites More sharing options...
NC Tom Posted September 12, 2018 Author Share Posted September 12, 2018 17 minutes ago, Pete M said: double check and clean all your connections. if you can't even turn on the headlights, that's gotta be a clue. That worked! Had a little rust on Neg connector and a little white film on Pos. Really bizarre how that works and how sensitive those connections are. Thanks Pete! Link to comment Share on other sites More sharing options...
