rockhardzj Posted August 24, 2007 Share Posted August 24, 2007 I need to know what the top of the tank looks like, so I know if it's possible to move the 98 XJ pump/sending unit into the 88 tank, or if the 98 tank will need to be retrofitted or what... Thanks in advance! Link to comment Share on other sites More sharing options...
mfpdm Posted August 24, 2007 Share Posted August 24, 2007 This one is off a 88 mj, 4cyl, 4spd, 2wd, swb. :cheers: Link to comment Share on other sites More sharing options...
rockhardzj Posted August 24, 2007 Author Share Posted August 24, 2007 :cry: How the friggin hell am I going to fit my sending unit in there?!?! I want to try to keep some room availible in the bed of the truck... I may find may find myself at the tractor supply store to find a fuel cell on a similar size for my new gas tank... Link to comment Share on other sites More sharing options...
cherokee Posted August 24, 2007 Share Posted August 24, 2007 Plastic tank vs. metal tank. Completely different. Retrofit the plastic tank to fit between the frame rails, it may be easier. Link to comment Share on other sites More sharing options...
rockhardzj Posted August 24, 2007 Author Share Posted August 24, 2007 cherokee said: Plastic tank vs. metal tank. Completely different. Retrofit the plastic tank to fit between the frame rails, it may be easier. Thats my other plan. Going to see how cheap a cell and pump is first. Link to comment Share on other sites More sharing options...
