1989 comanche mj Posted August 31, 2018 Share Posted August 31, 2018 One side of my Comanche has a rocker repair, basically bent sheet metal bondoed on the rocker and welded underneath. Its horrible. I have to replace the rocker, can't patch over it like a rusted factory rocker. Are there any usable ones out there now? Link to comment Share on other sites More sharing options...
krustyballer16 Posted September 1, 2018 Share Posted September 1, 2018 Negative. You'll have to make your own like I did out of ones out there. Gotta cut em apart and weld em back together I'm gonna try to see if I can have them reproduced though Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
PCO6 Posted September 1, 2018 Share Posted September 1, 2018 I was faced with this on my old XJ. I'm not sure how you use your MJ or if it's a look that that you'd want but I found it MUCH easier to go the 2"x6" slider route. I cut the original rockers out and found that a lot of the original sheet metal they were welded to needed repair/replacement too. I decided to gut everything and it made the job pretty straight forward. You could play a bit with 2"x5" or even 2"x4" tubing if you want to tuck the rockers in more to make them less noticeable. Link to comment Share on other sites More sharing options...
