Eagle Posted July 30, 2018 Share Posted July 30, 2018 A/C condensate drain tube is clogged -- it's peeing into the passenger's footwell. I can't find where the drain tube outlet is. Does anyone know? I thought it was supposed to run down inside the frame rail, but I've got it up on ramps and I don't see anything that looks like a drain tube. Link to comment Share on other sites More sharing options...
Eagle Posted July 30, 2018 Author Share Posted July 30, 2018 Got it. Comes out of the evaporator housing about 2 inches and stops. Doesn't "go" anywhere, it just pees on top of the frame rail. Can't see it from underneath -- that was my erorr. It's right there when you look down from above. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 31, 2018 Share Posted July 31, 2018 1 hour ago, Eagle said: Got it. Comes out of the evaporator housing about 2 inches and stops. Doesn't "go" anywhere, it just pees on top of the frame rail. Can't see it from underneath -- that was my erorr. It's right there when you look down from above. That sounds just like how my 91 A/C drains. I don't think they changed much over the years.. Link to comment Share on other sites More sharing options...
Eagle Posted July 31, 2018 Author Share Posted July 31, 2018 The earlier ones didn't drop the condensate onto the top of the frame rail, the tube extended down over the side of the rail and discharged directly onto the ground. Chrysler's bean counters must have saved at least 1.37 cents per vehicle with that change. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 31, 2018 Share Posted July 31, 2018 1 hour ago, Eagle said: The earlier ones didn't drop the condensate onto the top of the frame rail, the tube extended down over the side of the rail and discharged directly onto the ground. Not on mine. It drips on the rail. Link to comment Share on other sites More sharing options...
Eagle Posted July 31, 2018 Author Share Posted July 31, 2018 8 hours ago, HOrnbrod said: Not on mine. It drips on the rail. '91 was next to the last year for the MJ. It's an HO (betcha didn't know that, did you?). That's not "early" in XJ/MJ parlance. Link to comment Share on other sites More sharing options...
