Colorado: Shifters!
yellaheep
Someone HAS to want these!
Novak Adapters NV231 transfer case shifter. Nearly new, very little use. Complete. Retail for $190, sell $130 shipped!
RAD Designs Rock Shifter with Rail Controller, briefly installed and removed. Together cost $295, sell $220 shipped!  (Replaces OEM shifter, rail controller allows single gear selection and lock in.)
RAD Designs Baja Shifter, briefly installed, wired up and removed. Retail $160, sell $120 shipped!  (This can be used in conjunction with your OEM shifter, or with the Rock Shifter.  this mounts in the opening where the XJ e-brake handle/MJ ebrake delete area is in the center console - as I recall)
The Rock Shifter and Baja Shifter can be used together as well, the Baja shifter is just a large version of the Rail Controller.  If you were to build a custom center console/shifter box, they can go side by side.
RAD Designs is still in business and has excellent customer service and install hotline.  They'll answer all your questions about installing these!
Archived
