CavFab replacement ends
New territory for me since I usually try to stick to stock stuff. Went out on a limb and got Cav Fab short arms (uppers and lower) with heim joints. Not sure what they're like performance wise but on a daily driver it sounds like someone is smacking everything with a sledge hammer while driving. Was hoping there was something out there to replace the ends with regular rubber. I have the measurements for the adjustable bolt end just couldnt find anything VIA google. Everything seems to be the same type of metal heim joint.
As long as you got adjustables, you can get JJ's for them. only way to get factory rubber or poly is with the solid arms. I went with the alpha 3 link kit..rubber ends at the axle and JJ's at the frame. no issues here after 20k miles. Get ahold of David and he will explain more.
