No Blinkers
Hey folks, I'm kinda new to this whole MJ thing so forgive my ignorance! When I bought my truck last year the blinkers worked just fine, but ever since I had a steering column problem fixed a couple months ago, I have no blinkers whatsoever. I replaced the the flasher module, checked all fuses (that I could see) and checked the bulbs, but I still can't figure it out. Does anyone ave experience with this? I'm not sure if it matters, but there are no dash lights either. Though that has been that way since I bought the truck.
What problem with the column was fixed? Could the multifunction switch have been left unplugged, or its wires damaged? Does the turn signal stalk stay when you try to signal, or does it just spring back?
Regarding the dash lights, forgive me if this is obvious, but have you tried undimming them by rotating the knob on the headlight switch?
