Have an 88 4.0 Ba10. Refused to get into gear in when
hot in hot weather.
- replaced slave - refuses to go into gear when hot.
- replaced slave again - refuses to go into gear when hot.
- replaced clutch, fly wheel, 3rd slave - refuses to go into gear when hot.
- swapped to an Ax15, new clutch - refuses to go into gear when hot.
- replaced slave with a NOS master/slave...
You guessed it, it now doesnt want to go into gear when it gets hot...
I'm at a loss...6 master/slaves, 2 clutches, 2 flywheels, new transmission
and I'm still having a shifting issue (can't get into 1st or 2nd after about
40min of driving...) What am i missing????
Did you change the pressure plate. Did you torque the bolts on the pressure plate or did you just tighten them until good. I had an issue similar to this on my first mj it was the bolts on the bellhousing coming loose. Have a friend push the pedal in as you watch.
Sent from my Z982 using Tapatalk
