Jeep Driver Posted June 1, 2018 Share Posted June 1, 2018 A shot of gas or ether will tell you immediately. Did you replace the CPS? Link to comment Share on other sites More sharing options...
Krisbodean85 Posted June 1, 2018 Author Share Posted June 1, 2018 58 minutes ago, Jeep Driver said: A shot of gas or ether will tell you immediately. Did you replace the CPS? Yes I replaced the cps and if I shot a little carb cleaner it will run till it’s gone so I’m thinking it’s fuel related. I’m going to get a gas pressure gauge and see what the pressure is. What is the Renix 4.0 should be? It’s either going to be I think the pressure regulator or the fuel pump. Cause it’s running with the carb cleaner till it’s gone. Link to comment Share on other sites More sharing options...
Krisbodean85 Posted June 2, 2018 Author Share Posted June 2, 2018 23 hours ago, Jeep Driver said: A shot of gas or ether will tell you immediately. Did you replace the CPS? Yes I replaced the cps and if I shot a little carb cleaner it will run till it’s gone so I’m thinking it’s fuel related. I’m going to get a gas pressure gauge and see what the pressure is. What is the Renix 4.0 should be? It’s either going to be I think the pressure regulator or the fuel pump. Cause it’s running with the carb cleaner till it’s gone. Link to comment Share on other sites More sharing options...
