Flatbedmache Posted May 24, 2018 Share Posted May 24, 2018 Picked up an 88 comanche after rolling my xj. So gutted it and now I’m starting the rebuild. Started pulling the carpets to see what kind of work I have in store and it wasn’t as bad as I expected but definitely have some work going to be swapping over the leathers from a wj that I had in my xj to get rid of the bench seat. Switching the rad to an open system. Putting in a dual diaphragm brake booster. Swapping an ax15 for the Peugeot crap. Putting on some long arms and redoing the wood in the back of the deck. The list is really too long and it never really finishes anyway. Link to comment Share on other sites More sharing options...
Tuzmaster Posted May 24, 2018 Share Posted May 24, 2018 You can swap in wj seats onto an mj? What all needs to be done? Are they gonna be mechanical or electrical?Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
Finneys98xj Posted May 25, 2018 Share Posted May 25, 2018 More picture of you for bed please Link to comment Share on other sites More sharing options...
Flatbedmache Posted June 10, 2018 Author Share Posted June 10, 2018 I swapped seat brackets and took the motors off when I had them in my 2 door xj. Just need to mount the rails to the Mj brackets. Not too hard of a job. Wouldn’t be that hard to make them power but I don’t feel like doing that much wiring Link to comment Share on other sites More sharing options...
Flatbedmache Posted June 10, 2018 Author Share Posted June 10, 2018 Getting the upper unibody rail supports off is a big whore of a job Link to comment Share on other sites More sharing options...
Flatbedmache Posted June 14, 2018 Author Share Posted June 14, 2018 Got my new floor pans. Didn’t take a pic of the drivers side but it’s a 2 piece. Need to buy some 2x6 steel for the rockers and some sheet metal to fab up the cab corners and interior front rockers. Then more cutting out of all the bad stuff. Link to comment Share on other sites More sharing options...
Flatbedmache Posted July 9, 2018 Author Share Posted July 9, 2018 Started putting in the rockers today. Got the drivers mounted up. Need a few random things before we finish off and move to the passenger side. Link to comment Share on other sites More sharing options...
Flatbedmache Posted July 22, 2018 Author Share Posted July 22, 2018 Por15’d the inside of the frame rails today. Hopefully getting the passenger side 2x6 rocker on tomorrow Link to comment Share on other sites More sharing options...
Flatbedmache Posted July 28, 2018 Author Share Posted July 28, 2018 Dropped the gas tank. Going to replace with a fuel cell mounted on the deck. Got all the loots rust and dirt off the frame rails and as much and debris from the inside as I could. Going to prep and paint the rear frame rails in por15 and finally be done looking at any rust. Link to comment Share on other sites More sharing options...
Flatbedmache Posted July 29, 2018 Author Share Posted July 29, 2018 Link to comment Share on other sites More sharing options...
Flatbedmache Posted July 29, 2018 Author Share Posted July 29, 2018 First coat in por15 for the back frame rails Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted July 30, 2018 Share Posted July 30, 2018 16 hours ago, Flatbedmache said: First coat in por15 for the back frame rails looks good How many coats do you plan on doing? Link to comment Share on other sites More sharing options...
NickS Posted July 31, 2018 Share Posted July 31, 2018 Link to comment Share on other sites More sharing options...
Flatbedmache Posted October 9, 2018 Author Share Posted October 9, 2018 Been a while since I’ve realky progressed on the manche. Finally decided on what I’m doing though. The more I took it apart the less I wanted to put it back together the same way. So I bought a 97 xj and I’m doing the whole swap. Stripped the entire wiring harness dash steering firewall and everything else I could use. I’m living with boxes of Jeep parts in my living room haha. Back to the manche, I decided to add 2x6 braces in the middle of the rocker panels for support as I’m not putting the cover support over the frame rail and floor again. Floors are almost all cut and just have to get around to welding them in and then modifying the firewall slightly to get the 97 dash in. Maybe before it snows. Maybe. (Don’t laughs at the welding on the passenger side. Was my first time and wasn’t using gas Link to comment Share on other sites More sharing options...
