New control arms or replace bushing?
for lowers I would do new WJ arms (fully boxed with a bend for tire clearance).  just need to trim the steel bushings flush so they fit inside the pockets (and maybe a bit of the arm end itself as shown in the pic).  in fact you can do WJs for uppers too.    the bushings set in the axle are the only sticking point left since they are, well, in the axle not the upper arms.
When you say box in I'm sure your meaning weld flat stock over open back u shape stock then. Trim all factory edges? Upper will be get another set of lowers and make work? And this will let tje front axel sweep fowrad but centering more under the block from swinging down a few inches?
Sent from my Pixel 2 XL using Tapatalk
I mean the WJ arms are already fully boxed.  and use WJ uppers as uppers.  :L:  they are all the same length as MJ arms, just better built.
notice that I nipped back the top arm int his picture:
