No lights in dash or radio
Hey everyone. I'm having issues with my interior lights. I'm not getting any courtesy lights, dash lights, or radio lights. My headlights and taillights work. I've already changed the fuse and headlight switch. What else could it be? Thanks.
Wiggle the 5A instrument panel fuse around in the block some and see what happens.  Mine had a bad contact inside the block that would make intermittenty.....I had to wedge the fuse inside the holder so it would make constant contact.
Is your MJ a manual trans by chance?  If yes, check the clutch master rod for dripping fluid.  It is conveniently located directly above the fuseblock, and likes to drip fluid directly onto it.  No bueno.
