Sway Bar Bushing Kit
Yes, they can be mixed. I use the longer Moog K80035 Ford 350 end links because of the ~2.5" lift (a bit beefier than the stock links too) and since the pic was taken below poly bushings on the sway bar end. Also using poly for the #2 bushes.
Thanks.
That Unobtainium Engine Splash Guard looks to be
in real good shape. Check out that edge - WOW -:cool:
You had mentioned before, about using Fender Washers
with the Black Retainers for a more-solid hold.
youngfred
Re : Sway Bars Front/Rear
Are you running Greaseable Bushings on both ?
I noticed that the Addco 7/8" Rear Sway Bar Kit
#468 talks about longer End Links for lifts.
Does Addco sell those, also ?
I did not find those???
but it was way, way too late and the Mockingbird
was starting to sing, again. :beerbang:
"...I wanna go home to the Armadillo. "
youngfred
Yes, greasable bushings on both front and rear sway bars. I made my own by drilling and tapping a 1/4 x 20 in the middle of the bushing saddle, then punching a hole through the rubber bushing itself for a grease path. Did the same for the front bar, and they work great. You can see them in the below pic.
The rear bar on my longbed is a 7/8" Jeep WJ ADDCO.
Is the upper End Link mounting different for the Long Bed ?
I thought that I saw the End Link mounted to the
upper Shock Bolt ?
youngfred
