+97 XJ doors on MJ
I did a write up a long time ago.rhey wull bolt up, but you'll have to get the 97+ striker plate. I just used a piece of flat bar, drilled 2 holes and welded nuts on, then pried the old retainer plate off the inside of b pillar, dremeled out the hole for fitment and drilled new lower hole. wiring your on your own
Sent from my SM-G900V using Tapatalk
