kook911 Posted December 22, 2017 Share Posted December 22, 2017 So I got tired of not having a speedo or mileage, so I finally got around to do some looking the problem. Well it didn’t take long but I found it and now need some help. The wire that comes off the transfer case is not connected. When I did my swap I guess I never hooked it up. So can someone tell me where this wire hooks into? I don’t know if I even have it on the correct side. This is where I zip tied it and left it. Link to comment Share on other sites More sharing options...
Eagle Posted December 22, 2017 Share Posted December 22, 2017 What year MJ is this for? If this is for the '87 in your signature, your speedo is mechanical, not electrical. Link to comment Share on other sites More sharing options...
kook911 Posted December 22, 2017 Author Share Posted December 22, 2017 4 hours ago, Eagle said: What year MJ is this for? If this is for the '87 in your signature, your speedo is mechanical, not electrical. I have a 87 MJ but it has been swapped with a 91 XJ motor and drivetrain. So I’m electrical speedo but I don’t know where the plug plugs into. Link to comment Share on other sites More sharing options...
Eagle Posted December 23, 2017 Share Posted December 23, 2017 7 hours ago, kook911 said: I have a 87 MJ but it has been swapped with a 91 XJ motor and drivetrain. So I’m electrical speedo but I don’t know where the plug plugs into. The speedometer is not part of the drivetrain. Did you also rewire your dashboard as part of the engine swap? Link to comment Share on other sites More sharing options...
kook911 Posted December 23, 2017 Author Share Posted December 23, 2017 50 minutes ago, Eagle said: The speedometer is not part of the drivetrain. Did you also rewire your dashboard as part of the engine swap? Use the 91 motor harness and the 91 dash harness mated to the 87 rear harness. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 23, 2017 Share Posted December 23, 2017 The speedo connector (among other wires) on the 91 is on the right firewall circled in red below. I don't know what engine harness you have. Image3.psp Link to comment Share on other sites More sharing options...
kook911 Posted December 23, 2017 Author Share Posted December 23, 2017 1 hour ago, HOrnbrod said: The speedo connector (among other wires) on the 91 is on the right firewall circled in red below. I don't know what engine harness you have. Image3.psp Thanks I found that plug earlier and was about to post a pic here to confirm. So I just routed the plug on the wrong side. Got it corrected and we are good to go now. Thanks for the help Link to comment Share on other sites More sharing options...
