DDJeep89 Posted December 6, 2017 Share Posted December 6, 2017 My rear brake lights only come on when the brake pedal is fully depressed. I'm guessing it has to do with the brake light switch. I'm not sure how to correct the problem. I've seen that the bushings go bad but mine look to be ok. When I push up on the switch the lights will work. Anyone have some good advice? Link to comment Share on other sites More sharing options...
carnuck Posted December 7, 2017 Share Posted December 7, 2017 Flip the switch over on the pedal. My Comanches:2nd Louey 1987 SB Sporttruck2.5L/AX-4 2wd (for now) 3.55 D35 205/75R/15 with studs and new windshield and headliner. First Louey 1988 SB Sporttruck 4.0L/BA10/5 2wd (for now) 3.07 D35 235/75R/15 on steel wheels 90 MJ LB parts rig. 107K miles rustbucket from the belt 4.0/Auto with matching front axle for 2Lt. Link to comment Share on other sites More sharing options...
