Drop in longbed liner $35 Red Lund Sun Visor $200 98272
carnuck
Bedliner includes the tailgate panel with it. $35
Lund Sun visor from my ‘90 Comanche parts truck. $200
Tailgate (a bit of rust on the bottom)
$125 (no 4.0L emblem)
Or $300 for all 3 (Lund Visor, long bedliner and tailgate)
Ford 8.8 with 4.88 Posi, Nitro axles, chrome cover and rear drums. There is a little surface rust on the ABS ring and it needs cleaning due to the cover being partially open for an unknown time. Spring pads were removed already for centering .
$500 obo.
Note:
I have a TJ’s 2.5/ax-5/NP231 lined up for my truck so I just need to sell enough stuff to get it.
My Parts Wanted List:
RH MJ tail light.
Good Running 2.5L (mine has two cracked pistons from too many ether starts by PO) TJ Motor is the same. I missed on 3 of these motors due to no transportation.
4x4 AX-5 or 904 (auto can be a core), or bellhousing, flexplate and torque converter for AW4 to fit a 2.5L. I can swap for the same from a 4.0L off HO or Renix.
IMG_3299.thumb.JPG.44141cdb808ca635b52b24dfb5a5b6b8.JPGIMG_3297.thumb.JPG.1f98997ca2d539e8c2522076088cfdab.JPGIMG_3296.thumb.JPG.1e87e9ce7315d842483d4a3f03363e76.JPG
Archived
